Nice, congratulations. But - easy (or better: easier) on a Bosch engine compared to an ND-engine (see pic for when it happened in "Bruxelles", curve 10 of the racetrack of SPA 2010; almost threw me off the track...):
It wasn't by intention and it almost throw me down, as the rear tire got lifted and slid away... I was only able to safe me from a crash by pulling the bike up, which not only ruined my line but also took me off the track on the green, which made me almost drop the bike again... :-[ No fun at all...
I finished that round very slowly as my heard was pumping like hell and I was shaking by adrenalin so much, I could not ride fast anyway...
No need to try hard Cam. My method..... Just spend a few bucks on a coarse cutter for your angle grinder. Align carefully and apply your new cornering mastery. A few bucks more on a blue T shirt with a big red S on the front and the situation will be sorted. Instant riding super hero.
My real cornering technique is more like Captain Chaos. De de deeeeer.
Nah... you just have a half-decent suspension set-up Cam. Only time I've managed to deck that cover was when I got it terribly wrong in the Hatzenbach section of the N?rburgring Nordschleife many years ago. Perhaps I should add, the bike is raised a good 5cm... ;D
I once repaired a cover with a small chamfer for Grant, reckon that would be quite useful for just those decisive millimetres. Maybe he can post a pic of the finished item, it looked like a factory part, very similar to the 500 alternator cover.
THE S1 triple's alt cover is a PITA when racing with today's grippy tyres - even in the "Avon Series" days it was a problem. I had to end up with a tube that just covered the crank end on my Saxon/Motodd that I raced in 1999. It still just kissed the tarmac - especially at "clearways" at Brands Hatch - it ended up with a chamfer on the tube, along with the centre stand spring peg. Engine was about 2" (5cms) higher than std triple. - Regards - Phil
Michael Stoecker, who used to be the racer for Moto Witt's team in the 80's and beginning of the 90's I believe told me that on the RGS Corsa (or was it a TT1?!?) they used to race at that time, he even managed to grind the downtubes through. I suppose that was with a lifted engine, too...
This is all (mostly if not solely) happening on race-tracks. I have seen though people touching ground with a Series 1 engine on open roads. never saw that on a Series 2 bike except for when having an accident...
Series one or two, if you corner hard they will scrape, more or less depending on your riding technique. If you are close and hit a dip, good chance you are in for a crash. Not as bad as the junction box on SFs though.
Whitey ground down the thread on the crank end of the TTM series one Jota at Lakeside.
