townsend846
- London&essex
Hi all ,need a little more help finding a worm drive shaft for veglia housing,mine has a few teeth missing but gear is good
thanks good laverda people’s
Are they different than the twins ? And thanks for the replyAssuming its for the Triple in your avatar photo, I'd suggest it's probably best, since they wouldn't be a matched set, to fit new ones.
I got a pair from Wolfgang at Columbia Cycle.
I believe the early SF 750s, particularly the Smiths speedo equipped ones, are different.Are they different than the twins ? And thanks for the reply
Your dentist should be able to fix that.mine has a few teeth missing
Thank youIf you dont have any local luck, or decide not to buy new, let me know. I have a new one in Auckland city (NZ). Unfortunately I'm stuck in Wellington in Covid lockdown and wont be back there for a few weeks. I can look for it when I'm next home.
I found it in a box of parts I had. Must have been there for 35 years. Amazing how much better they are than Smiths ones found on British bikes
Try seeing a dentist at the moment in LondonYour dentist should be able to fix that.
Thank you I willIf you dont have any local luck, or decide not to buy new, let me know. I have a new one in Auckland city (NZ). Unfortunately I'm stuck in Wellington in Covid lockdown and wont be back there for a few weeks. I can look for it when I'm next home.
The speedo housing has this stamped into it paulVeglia?
Hi Andre I’ve had no luck at all locating one of these elusive gears and would be eternally greatfull if I could buy this from youIf you dont have any local luck, or decide not to buy new, let me know. I have a new one in Auckland city (NZ). Unfortunately I'm stuck in Wellington in Covid lockdown and wont be back there for a few weeks. I can look for it when I'm next home.
Thank youNo problem. I'll PM you
Nor I on a 750. I'll check.I can't remember seeing Veglia on a triple housing. Maybe I'm just unobservant.
Do you know who makes the speedo drive units ,have I got a after market unit fitted, gearing is 25 driver and 9 driven and definitely has veglia on it ,I’ll post a picture tomorrowMaybe it has the wrong speedo drive unit fitted?
I don't have Veglia on any of my machines.Do you know who makes the speedo drive units ,have I got a after market unit fitted, gearing is 25 driver and 9 driven and definitely has veglia on it ,I’ll post a picture tomorrow
I don’t know paul not found a Ducati I can afford,I will post a picture tomorrow when at work hopefully you might recognise itI don't have Veglia on any of my machines.
Wasn't there a Veglia drive on Ducatis?
