Now I'm wondering whether the braking load is carried by one rod or two. They'd have to be adjusted to precisely the same length for the load to be evenly distributed.
I gather from your mention of the turnbuckle alternative that all of your rose joints have a right hand thread, which gives an incremental adjustment of half a thread pitch as you turn each rose joint through 180°.
You can get rose joints (AKA Heim joints) with a left hand thread. That would give you the turnbuckle style continuous adjustment. Might be something to think about if you do any further development, especially if detaching the struts every time you want to adjust the chain is giving you the shits.
Very observant Cam, yes, if they are adjusted evenly with no slack one will be in tension, the other in compression, a bit of beneficial redundancy there. Because of the angle of the flat bar though, the top is 200mm, the lower 180mm.
I wanted them to meet at the Laverda welded bracket on the swing-arm for attachment, so the length is different, and also the flat bar can't fit at a perpendicular angle to them because of the caliper position constraints.
Observant again, a half-turn is the finest adjustment that I can make. The two joints are 90 deg aligned so that helps.
But setup is easy. I get the chain/wheel distance set right but leave the axle nut just snug so I can rotate the brake mount. Then set the two joints at the swing arm bracket.
The local bearing shop had the left hand Heim joints, but no left hand/right hand rod. Do you know if the left/right thread rods are readily available?
On the plus side, like the new wheel, this brake arrangement weighs less, and takes up less space than the old Laverda Brembo setup.
So, maybe move to the turnbuckles if I can source them.
