Author Topic: Paoli (square) fuel taps  (Read 3058 times)
Offline Piranha Brother 2
  • Hero Member
  • It was once a 1973 750 SF1
Re: Paoli (square) fuel taps
« Reply #15 on: November 07, 2019, 11:53 »
Holy shaez!!! :o :o :o
Offline Paul Marx
  • Hero Member
« Reply #16 on: November 07, 2019, 18:52 »
All in one unit with a longer filter/reserve than standard,.Italian made, .Some other taps have no ethanol resistant o ring,.Sold many for two years now.Never had an issue with fuel tube.
Hi Shaun,
Those are exactly the ones I have.
I only had the problem on one side of the S. I thinks I'm using Cavis green fuel line.
No issue on the race bike using the same replica taps.
Offline LJ-2
  • Hero Member
« Reply #17 on: November 07, 2019, 19:10 »
 (bigthumb)
86 RGA Sprint
74 3C
73 3C/1
73 GTF
1951 Gilera Saturno Sport
Offline Laverda SF
  • Hero Member
« Reply #18 on: November 07, 2019, 23:21 »
Actually my favored fuel Petcock as they are very easy to dissemble and clean: however, the inlet and outlet tubes are weak (Tend to break off) and corrode the threads when using modern Alcohol % fuels - For maintenance, I suggest you unscrew the inlets and outlets every 2 years, lubricate and use Teflon tape.
Aside for maintenance, you can depend on these Petcocks to stop the flow of fuel before it trickles over your pistons, wiping the bores and saturating the crankcase oil. Dellorto fuel bowls float needles can't handle to stop gravity feed.
Always Shut Off the Petcocks when you shut down your Breganzie - Even for 5 minutes ;o)
I never used the reserve stack ='s Missfire before you're empty.
« Last Edit: November 08, 2019, 00:01 by Laverda SF »
Offline Legs
  • Sr. Member
« Reply #19 on: November 08, 2019, 00:40 »
Good advice there Ron.
  • Hero Member
« Reply #20 on: November 08, 2019, 08:43 »
I'm baffled that for probably three decades of very regular use, main means of transport, touring, racing, commuting on my SF, I NEVER turned the fuel taps off and never once had the float valves cause my cylinder/s to flood. I agree it makes perfect sense to turn them off when stopped, and I'll try and make a habit of it when I get the spesh on the road, but seriously, never once turned mine off.
Offline AndyW
  • Hero Member
  • Mali
« Reply #21 on: November 08, 2019, 10:23 »
Same here: either “on” or “reserve”. Only used to use “off” when removing the tank or carb(s). Can’t say any of my mates did any different back in the day either. Only seem to be having problems with taps these days because I keep turning them on/off and am probably wearing them out..  (bolt)
« Last Edit: November 08, 2019, 10:26 by AndyW »
'71 TR6 Tiger, '73 X-75, '73 3C, '74 3C, '75 SF2, '75 850T3 Cal, '75 T160V, '78 Mirage, ‘78 SSD Darmah '80 SD Darmah, '82 TR7/T, '83 Tenere, '85 R80g/s, 2017 MV F3 (Ago edition)
Offline Grant
  • Hero Member
« Reply #22 on: November 08, 2019, 11:40 »
The difference is that today the parts are 40 years old, worn and /or damaged.
I have drained 8 litres of black 'water' from the sump, a mix of oil and degraded fuel.
Owner left the bike for 5 years with the taps switched on.
Luckily all the fuel had found it's way into the sump.
If the combustion chamber is full of fuel conrods WILL bend.
Check out my FB page, clublaverda.com
Offline Haggis
  • Hero Member
« Reply #23 on: November 08, 2019, 11:48 »
Exactly. The risk of the fuel tap leaking is undefinable, but the consequence of the risk is huge and expensive.  So why not just switch em off and lessen the risk?
Having said that, I'm working on getting a new-ish triumph scrambler at the moment. Has been stood for a while. Fuel tap firmly off, but ALL the fuel was in the sump. Off sometimes ain't off.
« Last Edit: November 08, 2019, 21:34 by Paul H »
History, eh! It's just one bloody thing after another.
Offline Is2
  • Hero Member
« Reply #24 on: November 08, 2019, 21:17 »
On the later model bikes [90's] with carbs that don't have a fuel tap to turn off,  does anyone fit petrol taps?
Offline AndyW
  • Hero Member
  • Mali
« Reply #25 on: November 08, 2019, 21:47 »
Settle...
Offline Paul Marx
  • Hero Member
« Reply #26 on: November 08, 2019, 22:55 »
They're already fitted aren't they?
Depression taps of some sort, or electro vanes.
Offline helicopterjim
  • Hero Member
  • No shit, there I was - and the crack was 90!
« Reply #27 on: November 09, 2019, 03:49 »
I searched electro vanes and depression taps ......... I'm still confused.
74 SFC
72 SF
74 3C
75 3C
79 (81) Formula Mirage 1200
Various Ducati's, Guzzi's, Puch's ... a BSA Sloper and maybe even an R90
I don't have a 1977 Honda XL 175 but I do have a Chang Jiang CJ750 with a sidecar.
Lone Butte, British Columbia
  • Hero Member
« Reply #28 on: November 09, 2019, 06:15 »
Do you mean vacuum-operated or maybe now, electric powered Paul? Fuels injected and pump operated have no probs.
The ZZR250 has CV carbs and the vacuum type fuel taps and the fairing makes it as good as impossible to drain the bowls when I park i knowing it could be months before I want to use it again. Just means I have to turn it over several times for as long as I dare each time to get fresh fuel into it (assuming the stuff in the tank ages better than the stuff in the bowls - or else the stuff in the bowls evaporates away?). Eventually it starts - huge testament to the tiny battery that often sits untended for 3 months.
Offline Laverda SF
  • Hero Member
« Reply #29 on: November 09, 2019, 08:32 »
It's the Dellorto float needle that tends to leak into your engine not necessarily the tank petcock valve . To ensure it does NOT happen always shut off your petcocks when you shut down.
« Last Edit: November 09, 2019, 10:47 by Laverda SF »
