Author Topic: 1200 TS fairing mounted mirrors  (Read 1697 times)
Offline maurice turner
  • Hero Member
« on: October 10, 2019, 12:12 »
Hi can anyone tell me if there is a match to the fairing mounted mirrors on a TS 1200 or have a pair they dont want.
I am just trying to use the existing holes in the fairing and not drill anymore.
81 Jota*7604*
Offline CLEMTOG
  • Hero Member
Re: 1200 TS fairing mounted mirrors
« Reply #1 on: October 10, 2019, 13:17 »
I am struggling a bit on that one Maurice as my memory fades badly, I do remember that they were a useless pair of mirrors and after a couple of years of ownership I had to make handlebars that suited me, which in turn meant shortening the fairing, which then meant losing the mirror mounting points, so no more fairing mounted mirrors since then, the reason that I cant recall what make they where is because I haven't had them for 38 years! what I do recall is that someone discovered that they were, or were very close to, a door mounted mirror on Ford cars, was it the Escort???
not much help, was it.
Offline Shamrock
  • Hero Member
« Reply #2 on: October 10, 2019, 13:58 »
Maurice,
I have a set of bases that I believe are for a TS.
Phil
Offline MarnixSFC
  • Hero Member
« Reply #3 on: October 10, 2019, 14:29 »
They used to fit different types mirrors to the TS, but most common were the Vitalonis of the RGS, only with the standard 2 screw fitting of that type (originally a car) mirror.
Marnix
« Last Edit: October 10, 2019, 17:13 by MarnixSFC »
International Laverda 750 SFC Owners Registry
Offline LJ-2
  • Hero Member
« Reply #4 on: October 10, 2019, 15:27 »
here ,my old TS. and correct blue screen.
86 RGA Sprint
74 3C
73 3C/1
73 GTF
1951 Gilera Saturno Sport
Online pf1
  • Hero Member
« Reply #5 on: October 10, 2019, 16:43 »
You're wrecking that bike Maurice  :D
Offline CLEMTOG
  • Hero Member
« Reply #6 on: October 10, 2019, 17:34 »
I am starting to think that series 1 Mirage 1200TS's are actually rare (whhoohooo) and Grant will no doubt chip in with something like, thank God for that.
almost all of the ones that you see are series 2
I don't think I recall the original mirrors as being Vitaloni Californians, I probably would have kept them if they were, maybe I had already smashed one flat, yes I think that was part of it, hairpin at Lydenn race track, I just cannot recall, but they were crap to use, as in you cant over about 80KPH
Offline Grant
  • Hero Member
« Reply #7 on: October 10, 2019, 17:56 »
I have seen these on series 1s before.
Check out my FB page, clublaverda.com
Offline lawrence
  • Hero Member
  • Idaho, USA
« Reply #8 on: October 11, 2019, 03:40 »
Those pictured are the ones that came on my 1983 Mirage.  They were so shoddy and poorly designed that they were removed from my bike.  Among other shortcomings, they wouldn't hold a set above around 40 mph.  Really a poor choice of mirror for any Laverda. I went with bar end mirrors and I'm completely satisfied with them. I then put small plastic plugs in the holes that remained in the fairing.
Idaho, USA
Online Vince
  • Hero Member
« Reply #9 on: October 11, 2019, 03:58 »
The ones in Grants pic look similar to the GSXR 1000 nock offs I have on the bevel fairing on my 3C. Japanese fairing mirrors tend to be of 2 types. Those that need a vertical surface to mount to and horizontal ones. I had CB 250 RR knockoffs fitted for a while but they are much narrower than the Suzuki ones, made the change after the cop who pulled me up asked why I hadn't seen him up my arse. Mounted through a rubber grommet and they work really well. Spacing of the mounting bolts is 35mm. Forget the name of the company who does them but they do blinkers etc and most bike shops or wreakers have their catalogue
Offline Gerald
  • Hero Member
« Reply #10 on: October 11, 2019, 07:04 »
Emgo?
Gerald
__o
_- \_<,
Online Vince
  • Hero Member
« Reply #11 on: October 11, 2019, 07:06 »
Ding Ding Ding, thats them.
  • Hero Member
« Reply #12 on: October 11, 2019, 11:50 »
They are the ones Grant 75mm hole centres if any one knows a match.
Sorry Pat you knew I couldn't help myself!!!!!!
81 Jota*7604*
Offline Gerald
  • Hero Member
« Last Edit: October 11, 2019, 12:20 by Gerald »
__o
_- \_<,
Offline Grant
  • Hero Member
« Reply #14 on: October 11, 2019, 12:30 »
I have these, 75mm centre, painted white.
Any use?
« Last Edit: October 11, 2019, 12:33 by Grant »
