Author Topic: 3C 1000 Starter Relay  (Read 1399 times)
Offline Brid Caveney
  • Jr. Member
« on: September 09, 2019, 02:44 »
Averted a disaster today -- when the Custom 3C we're just finishing building, had the starter relay stick -- when it was fired up for it's first test ride. Some frantic removal of side panels - to pull fuses, and praying it didn't toast the starter --- !! Is there a readily available (parts house USA) alternative to the old OEM one we were using?
Thanks.
Brid.
Offline Cosi
  • Hero Member
Re: 3C 1000 Starter Relay
« Reply #1 on: September 09, 2019, 16:55 »
The starter relay is the least of your problems....
Hastings Point 2489 Australia
Offline LJ-2
  • Hero Member
« Reply #2 on: September 09, 2019, 18:16 »
agreed.  :(
« Last Edit: September 09, 2019, 20:01 by LJ-2 »
86 RGA Sprint
74 3C
73 3C/1
73 GTF
1951 Gilera Saturno Sport
Offline laverdas
  • Hero Member
« Reply #3 on: September 09, 2019, 19:46 »
Another poor sod to the slaughter
Offline a14rgs
  • Hero Member
  • Wiltshire, U.K.
« Reply #4 on: September 09, 2019, 20:19 »
Disappointingly true >:(
However, Brid has rebuilt the bike to the customer's instructions - his bike, his choice - and it's another Laverda back on the road, so hopefully somebody can give a useful reply to Brid's perfectly reasonable query and suggest a good replacement for the starter relay :-[
1983 RGS1000, 154000km, owned and loved since 1989 😊
1977 Jota
1977 1200
"Team BFN - an international rabble on wheels"🏍🍻👍🤣😍
Offline Simon Y
  • Sr. Member
« Reply #5 on: September 09, 2019, 20:24 »
An adapted Aprilia RSV starter relay from ebay seems to be flavour of the month.
Series 2 180 Jota
750 Breganze
1200 Anniversary (previous)
Offline laverdas
  • Hero Member
« Reply #6 on: September 09, 2019, 21:09 »
hi alan/ brid , the starter relays can be serviced after all there only contact points so long as there not burnt out. i seemed to remember putting a bmw /6 on a triple years ago .
andy
Offline laverdas
  • Hero Member
« Reply #7 on: September 09, 2019, 21:11 »
sorry not a complete bmw/6 but just the starter relay :laugh:
Offline Dellortoman
  • Hero Member
« Reply #8 on: September 10, 2019, 02:02 »
Pretty much any starter relay will do the job. The original was probably a Bosch, with a mounting tang attached. I believe it was the same as those fitted to VW beetles of the era. Simplest solution would be to go to an auto electrical shop and buy something that'll fit in the space available. I'd suggest you get one rated to at least 100A, but a higher capacity one may last longer.
Alternatively, talk to one of the Laverda parts suppliers. I guess Wolfgang would be your nearest parts man. At least he's on the same continent as you.
Greg Parrish (DAM Laverda) also sells a neat little relay that'll do the job  https://damclassicracing.com.au/71306993-1-starter-relay-12v-dc-with-bracket/
Cam
Offline Gerald
  • Hero Member
« Reply #9 on: September 10, 2019, 06:31 »
I'm with Cam, try an get a 80-100 Amp relay. Seem to remember that O'Reilly has a good selection of automotive parts in store.
HTH
Gerald
__o
_- \_<,
Offline Cosi
  • Hero Member
« Reply #10 on: September 10, 2019, 12:20 »
Cam, you posted a few years ago of some cheap Chinese relay that you put in your Jota or race bike, Ive had one. In the gelati for at least that long and works fine, was like 6 dollars or something like that....
Offline CLEMTOG
  • Hero Member
« Reply #11 on: September 11, 2019, 10:39 »
I have used a proper car type solenoid (not a relay as originally fitted) it was super cheap and came from British Leyland, so Land Rover/Austin/Morris etc I fitted it underneath the battery tray as its a bit bigger, it lasted twenty years and then I bought another.
