Author Topic: Side stand Frame Plate  (Read 654 times)
Offline Alex M
  • Newbie
« on: August 23, 2019, 14:18 »
I'm looking for one of those frame plates mounted to the original foot rest thread. Already got a Kawa sidestand, so just need the mounting plate.
cheers,
Alex
Drive Fast!!
Offline Laverdalothar
  • Hero Member
Re: Side stand Frame Plate
« Reply #1 on: August 23, 2019, 16:10 »
Hi Alex, you mean the small plate, not the one with the brake-master holder I constructed, right? Can't help with the first, sorry.
750 SF(0) 1971 #9934 *sold*
1200 Jota 1981 #7474
750 S-Formula 2000 #1602
Offline Paul Marx
  • Hero Member
    • Les motos de Paul
« Reply #2 on: August 23, 2019, 16:25 »
cheers,
Alex
Ask Jotajoe on this list who makes, or made them.
Offline Alex M
  • Newbie
« Reply #3 on: August 23, 2019, 16:55 »
Hi Lothar,
yeah, looking for the small plate. I'll do as Paul suggested and get in touch with Jotajoe.
cheers guys!
Drive Fast!!
Offline Dellortoman
  • Hero Member
« Reply #4 on: August 24, 2019, 01:44 »
If Jotajoe no longer makes them, someone posted a detailed drawing on this forum a couple of years ago (I'll see if I can find it). You could use the drawing to make one. If you don't have the resources to do it yourself, take it to an engineering shop and get them to make one for you.
Here it is (attached as a pdf). I must have downloaded the original CAD file at some stage. I just converted it to a pdf file.
I dunno who drew it, but thanks for sharing.
Hang on, I just found another drawing (picture below) that someone produced. It differs slightly from the pdf drawing in that there's a recess milled at the top of the bracket to make it a bit thinner. As far as I recall from fitting one of these things about a million years ago, the recess is necessary for it to align vertically on the bike.
You'll also need a spacer (about 25mm long) to go between the plate and the engine mount in the middle hole of the bracket. Sorry, I don't have the exact dimension for the spacer or the length of mounting bolt required.
I assume the bracket shown in the pdf drawing uses a slightly longer spacer so doesn't need the milled recess for the footrest boss. That would make it simpler to fabricate at home.
« Last Edit: August 24, 2019, 02:09 by Dellortoman »
Offline Alex M
  • Newbie
« Reply #5 on: August 24, 2019, 20:51 »
Perfect!! Thanks, a lot!
That'll do for me. I can figure out the spacer once the plate is manufactured. :)
Alex
Drive Fast!!
Online AJ
  • Full Member
« Reply #6 on: August 24, 2019, 22:01 »
http://www.laverdaforum.com/forum/index.php/topic,89633.msg273867.html#msg273867
There has been upgrades to the Bushman/Lawton sidestand brackets over the years. The first brackets needed the center stand removed or the tang modified. Keith suggested moving the stand mount holes as shown in link. I did this to my Bushman bracket and it worked well on my bike and I can use either stand with ease and did not have to cut the tang on the center stand.
30th Anniversary 1200
750S Guiliano
