Author Topic: Dymo labelling your wiring loom...  (Read 1217 times)
Offline Yogi
  • Hero Member
  • Wamberal NSW Australia
« on: December 10, 2018, 10:35 »
Sounded like a great idea. Dead simple.  Looked magic last night, proper job.  Came home tonight and there’s Dymo confetti on the carpet all around the bike.
Fail...
Yogi
Yogi
1973 750 SF1 #15300
1974 750 SF2 #16555
1979 600 Barcelona Replica
1981 1200 Mirage #3341
1988 OR600 Atlas Series 3
1972 Yamaha TR3/TZB 350
Offline Gerald
  • Hero Member
Re: Dymo labelling your wiring loom...
« Reply #1 on: December 10, 2018, 10:43 »
use wire markers, like the ones from Brady. They will last forever.
HTH
Gerald
__o
_- \_<,
Offline CLEMTOG
  • Hero Member
« Reply #2 on: December 10, 2018, 10:49 »
if you are labelling the ends of the loom at connection points for some reason, I just use 20mm masking tape wrapped around in a "P" shape, and written on with a pen, cheap as chips and works for me, I had difficulty in believing how many cables were attached to a V12 Jaguar engine (installed) when I found the need to remove the unit in order to repair broken exhaust manifold studs on both sides, 100% impossible to repair in situ as is removing the manifolds from the engine (or for that matter the heads from it due to stud location, which is through the water jacket!, yes the studs are surrounded by water!) and as I progressed with my labelling, and worked away, I got a "feel" for a separate engine loom, which eventually I found one single, multi way connector to detach it, but I continued with my labelling, just in case, I needn't have bothered because I was not at that stage dismantling the unit, just repairing the studs, which I changed for s/s, and then they were forever coming lose!
Offline Paul Marx
  • Hero Member
    • Les motos de Paul
« Reply #3 on: December 10, 2018, 11:55 »
Fail...
Yogi
Never had a problem.
Some labels still there 25 years later.
Offline sweetas
  • Hero Member
  • in context....
« Reply #4 on: December 11, 2018, 02:35 »
Fail...
Yogi
Hey Yogi, you gotta pull the backing tape off dymo to get it to stick!   :-* :laugh:
79 Jota - No. 6256
Opinions are the medium between knowledge and ignorance...   Plato
Offline chrisk
  • Hero Member
  • I'd like to write something here: SOMETHING
« Reply #5 on: December 12, 2018, 20:22 »
 :laugh: :laugh: :laugh:
The initial attraction to motorcycling inflicts people for various reasons and at different stages in their lives. But once someone experiences the elation of riding a motorcycle there’s no denying the nearly spiritual effect it has.
Offline Alexol
  • Jr. Member
« Reply #6 on: December 16, 2019, 19:45 »
Old thread but anyway...
Either use the heat shrink Dymo label stuff, but you have to have the right labeller for that, OR, use the labels you used, put them on, then clear heat shrink tubing over the Dymo label.
Being both anal-rentative AND a bad electrician, I label everything.
Alex
