Author Topic: Ease my clutch  (Read 784 times)
Offline Grant
  • Hero Member
Re: Ease my clutch
« Reply #15 on: November 08, 2018, 18:49 »
2014-08-07 17.13.35 by Grant Duguid, on Flickr
and the matching brake lever:
2014-08-07 17.14.11 by Grant Duguid, on Flickr
www.clublaverda.com
Check out the daily blog
Offline Gravelroad
  • Hero Member
Re: Ease my clutch
« Reply #16 on: November 08, 2018, 18:53 »
I omitted the little choke lever, but that's the one I'm talking about. Thanks for the pic, Gant.
Offline Grant
  • Hero Member
Re: Ease my clutch
« Reply #17 on: November 08, 2018, 19:04 »
Standard clutch actuating arm, cable etc and the pull on the lever is similar to the hydraulic one on my Corsa (when I had it).
Changed the Corsa to a modern clutch and brake m/cs and they got lighter still.
2014-04-08 16.55.10 by Grant Duguid, on Flickr
2014-04-08 16.55.14 by Grant Duguid, on Flickr
www.clublaverda.com
Offline Gravelroad
  • Hero Member
Re: Ease my clutch
« Reply #18 on: November 08, 2018, 20:29 »
Still available with reasonable pricing at the Guzzi specialists: https://guzziepiu.de/shop/kupplungshebel-kompl-v10-centauro.html NOT - listed out of stock
« Last Edit: November 08, 2018, 20:35 by Gravelroad »
Offline LJ
  • Hero Member
Re: Ease my clutch
« Reply #19 on: November 08, 2018, 21:12 »
not sure how you log into their site.
1986 RGA Jota Sprint
1974 3C
1973 750GT
1971  750SF
 I was born to make mistakes,not to fake perfection
Offline lavgert
  • Hero Member
  • Vienna/Austria
    • Laverda Freunde Österreich
Re: Ease my clutch
« Reply #20 on: November 08, 2018, 21:54 »
... I use the older non adjustable Guzzi Daytona, 1100 Sport version, the longer actuating arm and a brand new cable - the lightest clutch you can imagine on a Laverda triple!!!
Ciao, Gert
1958 - 100 Sport
1974 - 250 Chott
1976 - 750 SFC Electronica
1977 - Sulzbacher 1000 3CL
1978 - Sulzbacher 1200 SC
Offline LJ
  • Hero Member
Re: Ease my clutch
« Reply #21 on: November 08, 2018, 22:06 »
1974 3C
1973 750GT
1971  750SF
Offline Piranha Brother 2
  • Hero Member
  • It was once a 1973 750 SF1
Re: Ease my clutch
« Reply #22 on: November 08, 2018, 22:23 »
I know the ergonomics of a dogleg are different (and i use Jap lever brackets from wreckers with doglegs), but isn't the fact that the clutch pull becomes (miraculously) lighter indicating that the pull ratio is different - which is essentially the same result of the easiclutch?
I've had my own easy clutch (happily slotted the cover) on the SF for decades and never had a problem getting neutral. With the new DAM lever I'm going to fit I cut it down and will only use the lower hole = longer cable pull but slightly heavier - will match my older custom version.
Offline Nat Magee
  • Jr. Member
Re: Ease my clutch
« Reply #23 on: November 08, 2018, 22:40 »
Get some silicone oil and spray plenty down the inner (I make a little funnel with electrical tape round the top of the outer). Makes the clutch feel a lot lighter.
Offline Paul Marx
  • Hero Member
    • Les motos de Paul
Re: Ease my clutch
« Reply #24 on: November 09, 2018, 08:28 »
As long as you don't have a Teflon or Nylon lined cable in which case it will soon stop cabling anything.
Online Tippie
  • Hero Member
Re: Ease my clutch
« Reply #25 on: November 09, 2018, 15:02 »
Guzzi e piu says  Nicht auf Lager (not in stock)
Gutsibits is lever only, at least on the linked page.
I like the look of these things, especially with the little choke lever on top, excellent.
Domino is the reincarnation of Tomasselli isn´t it?
SF2 17483 (race)
SF2 17424 (road)
