Author Topic: Silver cable ties  (Read 4432 times)
Offline Shajota
  • Hero Member
Re: Silver cable ties
« Reply #15 on: February 22, 2018, 21:50 »
So what do you use to lo keep your cables tidy?
Hollywood tape, all the glamours use it................... ;)
PETER
Offline motoddrob
  • Hero Member
« Reply #16 on: February 23, 2018, 05:20 »
There are a couple of cable ties, just out of sight. That was one of the criterias when I designed the body work and final look of the Motodd. All the electrics are contained in a closed box and using thin walled wire and a simpler wiring diagram the main loom going to the headlight area is on ly 12mm dia.and well hidden.
I also have a packet of stainless cable ties that I never ended up using.
Motodd 1200, SFC750
Offline drikko
  • Hero Member
  • Brisvegas
« Reply #17 on: February 25, 2018, 20:40 »
when I built Mike's Motodd I sat on Fleabay for a couple of hours searching for silver zip ties
did not find an exact silver but did buy grey ones
takes a while to troll through Fleabay when you search for something so common as Zip ties, you wind up with 87,532 results
Did you try searching 'cable ties silver', found these < min https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com.au%2Fulk%2Fitm%2F302217890993
Rgs1000 '83
Weestrom
Cosi prefers sailors
Breville Sandwich Maker
DISCLAIMER:- Anything I say may have been when I was sober so please don't take it personally.
'Bigamy is having one wife/husband too many. Monogamy is the same.' Oscar Wilde
