Author Topic: Laverda Jota Ownership, second time around. (ramblings)  (Read 316708 times)
Offline paulincayman
  • Full Member
Re: Laverda Jota Ownership, second time around. (ramblings)
« Reply #2760 on: December 01, 2019, 13:08 »
One of a kind I think, never seen another. Was made for a guy who raced a Jota before me.
Nice
Offline cbertozz
  • Hero Member
« Reply #2761 on: December 01, 2019, 21:12 »
Eye Hospital for me on Friday the 13th and the CIMA ride on Saturday the day after. Hopefully, I can take Brett up on a shim check and starter motor look-see sometime as well. I miss my bike and it needs a good tubing and oil change after Tassie
See you at ride on 14th  :)
1978 Laverda Jota #6041
First owned in 1991, reacquired 2016.
Offline cbertozz
  • Hero Member
« Reply #2762 on: December 02, 2019, 11:41 »
I swear suspension changes according to the barometer. Took the heavier springs for a run today and hated them. Lighter springs back in, sag checked again, the rear has less preload on it now to get the sag in the zone. Tyre pressures adjusted. Ready to go.
Offline cbertozz
  • Hero Member
« Reply #2763 on: December 03, 2019, 00:38 »
Order is restored, a rideable setup.
Offline cbertozz
  • Hero Member
« Reply #2764 on: December 03, 2019, 02:39 »
When I set sag I also like to take a quick video to see how the rebound is working. Itís not for fine tuning but does spot when one end is rebounding noticeably faster than the other. Scrubbing the video slows it down to make that easier.
[/youtube]
Offline cbertozz
  • Hero Member
« Reply #2765 on: December 03, 2019, 04:13 »
Avonís official tyre recommendations:
https://www.avontyres.com/en-us/tyre-care/technical/avon-general-tire-pressure-guidelines-1.pdf
Solo is based on 90kg rider.
Two up light equates to heavy bike and rider.
So Iím now running 26 front and 30 rear. Letís see if that makes the ride better still.
Offline Vince
  • Hero Member
« Reply #2766 on: December 03, 2019, 04:20 »
? that's really low for road pressures. I have Bridgestone T30 fitted and was running 37 front and 40 rear, recently changed its now 34 front. Their radial tyres though.
Offline Vince
  • Hero Member
« Reply #2767 on: December 03, 2019, 04:35 »
So that's their Classic recommendations. I wonder what they call classics. I think I would be using there Sports/ Sports Touring section.
Offline cbertozz
  • Hero Member
« Reply #2768 on: December 03, 2019, 04:48 »
Offline martymoose
  • Hero Member
« Reply #2769 on: December 03, 2019, 06:55 »
Gravity muscle working then I see.....
Cheers from sunny Sydney
Offline cbertozz
  • Hero Member
« Reply #2770 on: December 03, 2019, 07:01 »
Footpegs still on too, AMAZE! :laugh:
Offline cbertozz
  • Hero Member
« Reply #2771 on: December 03, 2019, 07:48 »
Riding at the moment has the hazard of the equivalent of smoking 40 ciggies a day due to the bushfire smoke. Hope everyone is staying safe where they are close to the flames as well. Managed to get out this morning but this afternoon was a non-starter.
Offline cbertozz
  • Hero Member
« Reply #2772 on: December 04, 2019, 08:19 »
So Iíve been thinking about spring diameter i.e the amount clearance between the spring and the inside of the fork. The 1.1 spring from racetech doesnít fit in the fork. The 1kg and .95 racetech fit but Iím wondering whether itís binding at all.  I have another .95kg spring which is narrower and longer so Iím going to see how that behaves. Will cut the spacers tonight.
« Last Edit: December 04, 2019, 08:50 by cbertozz »
Offline cbertozz
  • Hero Member
« Reply #2773 on: December 04, 2019, 11:02 »
Springs changed, same sag thereabouts (not surprising given spacers cut shorter and same spring weight. Will see tomorrow.
Offline Dellortoman
  • Hero Member
« Reply #2774 on: December 04, 2019, 23:30 »
Springs in compression will increase their diameter as they compress. So if the spring is a tight fit when relaxed, it could bind when it compresses.
