Author Topic: Re: What did you do to or for or with your Laverda today?  (Read 1129325 times)
Offline Paul LeClair
  • Administrator
  • Hero Member
  • the older I get, the faster a rider I used to be
« on: September 02, 2014, 23:27 »
my RGS is back together and running well, new battery, middle Mikuni fuel bowl patched with JB Weld and no leaks, so far........
Paul LeClair
Paul LeClair
Calgary, Alberta, Canada
79 1200 Mirage, 82 1200 Mirage, 84 RGS Executive, and various non Laverda's
Terry Dymond
  • Guest
Re: Re: What did you do to or for or with your Laverda today?
« Reply #1 on: September 02, 2014, 23:49 »
New rear tyre fitted, swingarm pivot greased; chain removed, cleaned and refitted; wheels string aligned, rear brake bled. The pre-rally preps continue. Like to do my maintenance at home, not at the side of the road ::)
Offline AndyW
  • Hero Member
  • Adelaide
« Reply #2 on: September 02, 2014, 23:56 »
Don't forget to oil your wetsuit... or the rain dance... or...
'71 TR6 Tiger, '73 X-75, '73 3C, '74 3C, '75 SF2, '75 850T3 Cal, '75 T160V, '78 Mirage, 78 SSD Darmah '80 SD Darmah, '82 TR7/T, '83 Tenere, '85 R80g/s, 2017 MV F3 (Ago edition)
Terry Dymond
  • Guest
« Reply #3 on: September 02, 2014, 23:59 »
Submarine escape suit and floaties packed ;D
Davo
  • Guest
« Reply #4 on: September 03, 2014, 02:44 »
Gear shifter adjusted, new neutral switch fitted and adjusted as longer than the original and prevented gear shifts, new shifter cover gasket from Red fitted, oil in. Up and down the road a few times, now shifts through all gears smoothly with no false neutrals. Only prob now is front end chatter under brakes - methinks the headstock could do with a bit of tightening, and then off to the coppers for inspection and hopefully rego.
Offline Dellortoman
  • Hero Member
« Reply #5 on: September 03, 2014, 03:22 »
Check your disks for run-out too.
Davo
  • Guest
« Reply #6 on: September 03, 2014, 03:27 »
Bloody hope not. Brand new EBC rotors and floating stainless discs.
Offline Laverda Bomber
  • Hero Member
« Reply #7 on: September 03, 2014, 04:02 »
I need new glasses. I thought you said check your dicks for runout!!!
Laverda Bomber
Tasmania Aust (Not Transylvania or Tanzania)
1980 Moto Martin 1000 Laverda Triple
2004 Ducati SS800 Track Bike "Cicciolina"
1977 VW Kombi Campmobile
Offline drikko
  • Hero Member
  • Brisvegas
« Reply #8 on: September 03, 2014, 04:30 »
Nothing to the bike itself today but I did find this when tidying up my desk, from my daughter a few years ago.... maybe it should go in the calendar for April? Whatever I'm supposed to be doing it doesn't look like it will end well!!
Rgs1000 '83
Weestrom
Cosi prefers sailors
Breville Sandwich Maker
DISCLAIMER:- Anything I say may have been when I was sober so please don't take it personally.
'Bigamy is having one wife/husband too many. Monogamy is the same.' Oscar Wilde
Offline Jimmy
  • Full Member
« Reply #9 on: September 03, 2014, 05:42 »
Hey Dricko, Me thinks you just realised you've got no brakes :laugh: :laugh: :laugh:
Jimmy
76 SF3, 81 V50 Monza, 02 Triumph Daytona, 81 Ducati Alchemy
  • Hero Member
« Reply #10 on: September 03, 2014, 07:26 »
She did weel making it look like an Argee!!
Laverda Bomber
Offline HansL
  • Sr. Member
  • 10 kms north of Amsterdam
« Reply #11 on: September 03, 2014, 07:50 »
Bit of a load for a 500! Still on my bucket list but it's getting closer :-)
The 500 didn't seem to have too much trouble with it, as long as its revved enough.
I think the Reliant of my friend Johan de Haas had more trouble getting up there.
But he got applause when he made it.
750GTF '70 - 1000 3CL '77 - 500 '77 - 500 Montjuic '79 - 500 Formula '80 - 600 Atlas '88 - 600 Atlas '89 - Morini 350 SS '75 - Gilera Saturno '89 (3x)
Offline paparracas
  • Full Member
« Reply #12 on: September 03, 2014, 13:45 »
I installed the main light LED 2000 lm. (12W low / 18W hi.). All lighting is LED.
Now, the light of highway consumes less than the position light, idling is charging a battery (12,80v-13,20v). with the original alternator.
Ignitech and LED bulbs have solved my battery charging problems.
Greetings.
Offline cape
  • Hero Member
  • rocketeer...yeah right
    • Scuderia Laverda Finlandia
« Reply #13 on: September 03, 2014, 15:49 »
Went for a ride, Lovely.
Noticed that the cam cover gasket is leaking, Blimey.
Well, new one has been ordered.
Question: How thick should the gasket be? The one I have is about 1,5 mm and the groove on the cover is only couple of tenths of millimeters less deep.
Laverda 1000 Jota, 3/4 rhythm rocket!
Offline Grant
  • Hero Member
« Reply #14 on: September 03, 2014, 15:55 »
1.5mm should be ok.
One of mine had a leak because the rubber seal was (from memory) 1.2mm thick. Pretty sure the replacement was 1.8mm thick.
Check out my FB page, clublaverda.com
