Author Topic: 630 to 530 conversion  (Read 20548 times)
Offline Dellortoman
  • Hero Member
Re: 630 to 530 conversion
« Reply #45 on: May 25, 2011, 07:52 »
Might be worth browsing through the sprocket drawings in a JT Sprockets catalogue to see if you can find a sprocket with the same spline centre as the 500 Laverda.
I found a Yamaha sprocket that fitted the spline on my Benelli when I converted it from the original duplex chain to a 530.
Cam
Offline Andy
  • Full Member
« Reply #46 on: July 28, 2019, 08:59 »
In the interests of those searching for information in the future, I'll dredge this old thread up to ask a question or two:
If I replace the 630 chain on my RGS with a 530:
- how many links will the 530 chain be?
- is either sprocket a "standard" fitment or are they model specific?
And as an aside, does anyone have strong opinions on whether I should use a riveted or clip link?
'84 RGS and loving it
(might have to sell the old honda...)
Offline sfcpiet
  • Administrator
  • Hero Member
  • NRW, Germany
« Reply #47 on: July 28, 2019, 10:37 »
The chain requires 108 links with 19/40 sprockets.  Sprockets front and rear are standard 180 bits, take your pick, providing you're running stock Laverda wheels.
AfaIk, at least DID no longer supplies chains larger than #520 with clip links.  As chain clearance between crankcase and frame can be an issue once some slop develops, a clip cannot be recommended anyway.
180s feel quick, 120s are...      If it ain't broke, fix it till it is.
"A motorcycle is a bicycle with a pandemonium attachment and is designed for the especial use of mechanical geniuses, daredevils and lunatics"  Georg Fitch 1916
Offline LJ-2
  • Hero Member
« Reply #48 on: July 28, 2019, 18:55 »
I did have a big heavy endless chain on the Sprint with non standard CMA wheels but have run on Andychains lighter Iwis 530 with split links for awhile now.  :-\
« Last Edit: July 28, 2019, 19:00 by LJ-2 »
86 RGA Sprint
74 3C
73 3C/1
73 GTF
1951 Gilera Saturno Sport
Offline Andy
  • Full Member
« Reply #49 on: July 30, 2019, 10:05 »
Perfect, thanks Piet
