LaverdaForum
Laverda Forum => Ride and Race reports => Topic started by: martymoose on September 09, 2019, 09:11
Title: CLQ October long weekend
Post by: martymoose on September 09, 2019, 09:11
5,6,7 October, I heard a rumour.....
Title: Re: CLQ October long weekend
Post by: LaverdaIan on September 09, 2019, 09:24
Yes you did Marty.. same bello channel, same bello time,
Be good to see you blokes.. better talk to BK to arrange..
 8)
Post by: Vince on September 09, 2019, 09:50
If i said obviously easy river crossing in the drought but i just heard its snowing at armadale with a major bushfire there at the same time so who knows
Post by: martymoose on September 12, 2019, 12:13
I spoke to Bruce will send out an email and text, need numbers for the catering.
Post by: Jotaman on September 12, 2019, 23:38
We are all over it this year - pontoon bridge, lifeguards: we've got it all
Peter
Post by: martymoose on September 13, 2019, 04:13
Windsor
Singleton
2 1/4 hrs
180 km fuel
East Gresford
Dungog
Gloucester
2 hrs
132km fuel
Uralla
2 1/2 hrs
191 km fuel
Armidale
Dorrigo
Bellingen
2 1/4 hrs
177 km fuel
9 hours
680 km
4 fuel stops @ 15 mins each 1 hr
Lunch 1/2 hr
Say 10.5 hrs
Leave Windsor 7am
Arrive Bellingen 6 pm
No speeding double points weekend 😳
Post by: martymoose on September 27, 2019, 23:29
5 riders leaving Wilberforce BP at 6.30am next Saturday. If you want to join us let me know
Marty
Post by: Dellortoman on September 28, 2019, 01:34
My brother Tim and I thought about joining you guys, but only briefly. It's a bloody long ride from the bottom end of Tassie, not to mention the cost of getting across Bass Strait.
I reckon I'll save my travel budget for the Phillip Island Classic in January.
Enjoy the ride and stay safe guys.
Post by: Vince on September 28, 2019, 01:37
Wish I could come, have fun. BTW the real tricky bit isnt the river, its the right turn and step down to the riverbank close to the road especially leaving when the river crossing water dripping off the bikes and wets that climb. That's not so easy when it's wet. Ask Doug R. All part of the fun.
Post by: hooksey on September 28, 2019, 03:31
Dougee  8) spent a bit of time by the riverbank and in BKís shed searching for some nuts and bolts to send DOUG on his way!
Has a great story to tell!
Good luck to one and all on the ride and festivities. Have a blast  ;)
Hooksey.
Post by: Vince on September 29, 2019, 06:54
Marty check the bushfire app closer to the weekend, the Waterfall Way was closed yesterday because of the fire near Armadale and the weather report for the long weekend is mid-30s up here. Armadle 28c on the weekend.
Post by: martymoose on September 29, 2019, 09:00
Yep heard about that one will keep an eye out
Post by: martymoose on October 05, 2019, 06:32
Made it 500 km up the road no gears on the 120 Jota at least itís not bfn they have beer in Walcha
Post by: Vince on October 05, 2019, 06:37
Zero gears or stuck in one gear, selector spring issues?
Post by: Dellortoman on October 05, 2019, 08:41
Check that the chain is still there.
Post by: martymoose on October 05, 2019, 21:54
Great cheesecake at the royal cafe.
Post by: Vince on October 06, 2019, 03:01
Radio silence, no news is good news? The 2 issues like this that have happened to me over the years are sticking sceazed footpeg gear lever pivot, happed 2 or 3 times fixed with WD40 and a strip and regrease at home, seems no one else on earth has had this happen ever and a broked selector spring that still allowed use by lifting the lever slightly and then selecting gears. Someone lost a bolt in the rear set linkage once, easy fix.Anything deeper and its trailer time. Hope Marty hasn't dropped cheesecake on the clutch.
Post by: Dellortoman on October 06, 2019, 07:30
I've had the M6 bolt that holds the little lever arm on the end of the gear shaft come loose on more than one occasion. It's the type used on the crossover gear linkage with the two flats on the shaft and slotted hole in the lever arm. It only needs to loosen a couple of turns and the arm will slip off the end of the shaft. It's obvious when it happens because the gear pedal dangles down all limp and impotent. Got sick of it happening so ended up Loctiting it in. If it works loose again I'll drill the bolt head and lock-wire the bloody thing.
Post by: martymoose on October 06, 2019, 09:15
Just home now after a 10 hr round trip for Ross to pick me up with his Ute. Will pull it apart tomorrow. No phone signal at the rally site so guess that they are going well
Post by: Vince on October 06, 2019, 10:17
Buggar, happy you made it back to base.
Post by: martymoose on October 07, 2019, 03:26
As suspected, bugger! On the upside first time primary cover off in 85000km everything in very good condition
Post by: AJ on October 07, 2019, 04:13
I give up. What's that Marty?
Post by: 81Lav on October 07, 2019, 04:15
Great weekend up here.
All now departed and heading home.
Sorry you missed it Marty.
BK
Post by: Dellortoman on October 07, 2019, 04:39
Looks like a spider's leg.
Post by: bazzee on October 07, 2019, 05:06
Looks like someone's left hand to me.
bazzee
Post by: martymoose on October 07, 2019, 05:17
Thatís the short end of the broken spring the one  that holds the gear shifter onto the selector drum.
Sorry I didnít help you with all that food & grog, but Iíll catch up with CLQ again soon, thanks Bruce.
Post by: markQLD on October 08, 2019, 07:32
BK
+1
Many thanks to Bruce & Naz
Thanks also to CLQ and the NSW blokes
Good times were had
(http://www.laverdaforum.com/gallery/albums/userpics/10581/2019bello-311_01.JPG)
 , some more pics
https://flic.kr/s/aHsmHxWCqe
Post by: LaverdaIan on October 08, 2019, 08:12
2 questions.. well 3 actually.. ;)
What is Rob doing on the soapbox..?
What is the story of the broken Jota in Horney's FB pics..
And.. why didn't I go..? DKHD of the year perhaps..?
looks like another great weekend Mark.. good on you all.
 8)
Post by: Brett on October 08, 2019, 20:19
So we had a wet start to the weekend got to the meeting point and no Cosi wasnt a damn Macca's fueled up and off we headed up a wet Putty Road. Got fuel at Singleton and the rain still persisted in parts but around Greta abated. Somewhere on the way into Dungog round a bend had a close encounter with a skippy which I narrowly missed then hoped that the big 120 Jota of Marty's who was in close proximity to me at the time missed it also. Boy that was a close one. Then brekky at Glouchester and then a run up Thunderbolts which was kind of fun apart from a few cars and a truck causing some delays..Just after Walca I looked in my mirrors and no one behind so I had to do a u turn and came across the stricken moose out of gears. we hypothesized for about 20mins a quick call to Paul for a rescue mission, offered to double Marty the rest of the way but he declined something about the barmaid at Walca was more of interest so we parted ways. Very low cloud into Dorrigo meant vision was down to Zero had a few BMW's and KTM's in front who had their hazaards on which was kind of good in a way but was mindful that if one lemming goes off the road the rest of us might follow.
Got to Bellingen about 5ish and onto the property about 5.30 to meet up with the Qld crew.
Great night
Nest day got roped into cooking up brekkie with Crazy John then got talked into a hangover curing run with Levo on our Laverda's along with his young bloke and a couple of others, found some amazing roads near Bowraville thanks for the tip Bruce.
That night cooked up another storm bloody amazing weekend shame Marty missed it as I reckon he would have helped out by drinking lots more beet to make less to cart back for the boys as there were still a good few full cartoons there at the end.
Trip home was down to one 180 and a sole 120 now....  old road to Nambucca then Pacific to Wooten way then Buladelah to Glouchester and then onto Greshford again god I must love that road ( you know the one that Chris K hates ) then an amazingly great trip back down the Putty with Will in tow... hardly a car in sight except for one or two Mr Plods.
Silver Jota ran awesome all weekend excepting where it just didnt have enough grunt to keep up with Levo's Redax built RGS when he blasted past and i tried to catch back up... though for the trip it used 3/5th's of stuff all oil ............now ready for an oil change
(https://www.laverdaforum.com/gallery/albums/userpics/11173/IMG_3079.jpg)
(https://www.laverdaforum.com/gallery/albums/userpics/11173/IMG_3081.jpg)
(https://www.laverdaforum.com/gallery/albums/userpics/11173/IMG_3082.jpg)
(https://www.laverdaforum.com/gallery/albums/userpics/11173/IMG_3083.jpg)
(https://www.laverdaforum.com/gallery/albums/userpics/11173/IMG_3087.jpg)
(https://www.laverdaforum.com/gallery/albums/userpics/11173/IMG_3084.jpg)
(https://www.laverdaforum.com/gallery/albums/userpics/11173/IMG_3085.jpg)
(https://www.laverdaforum.com/gallery/albums/userpics/11173/IMG_3086.jpg)
(https://www.laverdaforum.com/gallery/albums/userpics/11173/IMG_3088.jpg)
(https://www.laverdaforum.com/gallery/albums/userpics/11173/IMG_3090.jpg)
(https://www.laverdaforum.com/gallery/albums/userpics/11173/IMG_3093.jpg)
(https://www.laverdaforum.com/gallery/albums/userpics/11173/IMG_3091.jpg)
(https://www.laverdaforum.com/gallery/albums/userpics/11173/IMG_3092.jpg)
(https://www.laverdaforum.com/gallery/albums/userpics/11173/IMG_3096.jpg)
(https://www.laverdaforum.com/gallery/albums/userpics/11173/IMG_3097.jpg)
(https://www.laverdaforum.com/gallery/albums/userpics/11173/IMG_3099.jpg)
(https://www.laverdaforum.com/gallery/albums/userpics/11173/IMG_3101.jpg)
(https://www.laverdaforum.com/gallery/albums/userpics/11173/IMG_3102.jpg)
(https://www.laverdaforum.com/gallery/albums/userpics/11173/IMG_3103.jpg)
(https://www.laverdaforum.com/gallery/albums/userpics/11173/IMG_3105.jpg)
(https://www.laverdaforum.com/gallery/albums/userpics/11173/IMG_3113.jpg)
(https://www.laverdaforum.com/gallery/albums/userpics/11173/IMG_3115.JPG)
(https://www.laverdaforum.com/gallery/albums/userpics/11173/IMG_3114.jpg)
(https://www.laverdaforum.com/gallery/albums/userpics/11173/IMG_3136.jpg)
(https://www.laverdaforum.com/gallery/albums/userpics/11173/IMG_3140.jpg)
(https://www.laverdaforum.com/gallery/albums/userpics/11173/IMG_3141.jpg)
(https://www.laverdaforum.com/gallery/albums/userpics/11173/IMG_3142.jpg)
(https://www.laverdaforum.com/gallery/albums/userpics/11173/IMG_3143.jpg)
(https://www.laverdaforum.com/gallery/albums/userpics/11173/FullSizeRender.jpeg)
(http://)
Post by: andre g on October 08, 2019, 21:14
nice pics, nice petrol stations ;-)
Post by: TC on October 08, 2019, 21:26
Thanks for the wright up and pics Brett, nice work, looks like a top weekend. shame the weather was so sad at the beginning.
Post by: lowy on October 09, 2019, 10:36
We are off to Bellingen, we met at Kyogle at 9:00 on Saturday morning for a 9:30 leave.
We headed for Casino- Grafton, fueled up and headed towards Ebor. The road was a little slippery on the way up the range, so that slowed me down a bit. When we reached the Ebor-Dorrigo road the cloud was like pea soup, so it was an even slower ride into Dorrigo for lunch. We started heading down the waterfall way when we came across road works, and wet white lines that had to be crossed. Iíve crossed many of these in my days, but this one put me on my arse. My poor old Jota was not rideable anymore. Onto a trailer and down to Bruce and Narz place for another great weekend. Bevelman had sent photos of my damage to Red, who told me to take it to the Redax shed when we got back to Brisvegas, so we got to the shed on Tuesday morning, and Red had all the parts I needed to get it back on the road, within a few hours it was back on the road. I canít thank Red enough, for how he dropped everything to get me going. You one good man Red, and all of us are so lucky to have you in our Laverda world. Iím pretty sure there wouldnít be another Laverda ship in Australia that would do what you have done for me. Thanks again Mate
Post by: Cosi on October 09, 2019, 11:25
Lowy, Iím sure I gave you 3k cash for that wreck on Saturday night, we had a deal man...
Post by: martymoose on October 09, 2019, 11:44
Yes that is caramel cheesecake in the brekky photo from gloucester😛  Ended up spending the night at the royal cafe in Walcha, with Brad & Toni, great hosts.  The guys and gals from the Brisbane cafe racer club where staying there, great bunch of guys.  Sorry i missed the clq party.  Brett dropped off the new spring tonight so ill get the jota back together for tassie.  Thanks guys
Post by: martymoose on October 09, 2019, 11:52
Oh yeah that kangaroo was on a death wish!  Must have missed Brett by less than a metre, then sat down in the middle the road!   I aimed for it hoping it wouldnt be there when i got there, it darted off to the left, phew!  Brake upgrade anyone?
Post by: DavidH on October 10, 2019, 01:59
Great weekend with the Queensland boys and gals at Bruce and Naz's .
Was good to catch up with older friends, meet a few new ones (putting faces to names and nick-names) and enjoy the magical property that is Bruce and Naz's.  Us NSW chaps were made very welcome by the QLDers, and a vast amount of food and drink was at hand !
Waking up the the birds calling fin the surrounding forest and going to sleep with a frog chorus from the river just topped the weekend off for me.
Marty very stoic with his gearless JOTA just out of Walcha.  Felt very strange to leave him heading back into town, but at least he was able to check out the Royal Cafe and the bike owning owners.
I went north to visit friends up north of Grafton, being passed at a great rate of knots by Tom and his partner on their red 180 JOTA in the mountain bends, then coming across Levo and young Jack stopped by the side of the road.  Jack's TRX had decided to sound like a tin can of nuts and bolts.  No further riding possible so was left in a farm for later retrieval.  Jack hopped on the back of Levo's RGS with a bit of luggage re-arrangement.  I'm sure I heard him say to dad - "take it easy".  Maybe Levo didn't hear ?
So an RGS, CORSA and a JOTA continued on, however Levo/Jack stopped before Grafton and Tom very kindly led me through Grafton in 38 degree heat, then to the ferry at Lawrence, where I could cross the Clarence River and get to Maclean.
Thanks heaps Tom, much appreciated - as was the fact the HWP car going the opposite way south of Lawrence was boxed in behind a truck, so didn't get to ping us.
Return on Tuesday afternoon was a good run down the Waterfall Way to Armidale, then Thunderbolts Way with the mountains end in the dark to Gloucester. The wind north of the mountains was crazy, with gusts providing some interesting experiences on the open tops.
Early am return to Sydney.
Another great LAVERDA weekend away.  Thanks again to Bruce and Naz and the CLQLD gang, top weekend.
Post by: sweetas on October 10, 2019, 08:13
Hey Dave,
It's not Red, its Orange. It's not Tom, its Tony.  But its all good, was a pleasure!   Oh yeah, another Petrol Station pic!
Post by: levo on October 10, 2019, 10:30
Yea was a top weekend , a bit of a bummer about Jak's trx , itwas going really well till it wasn't. A big thankyou to  Tony and Chantelle for the use of their van to go and pick up Jaks bike,it would have been a much more difficult job to do if it wasn't for their help. Their was even a bit of comedy in that adventure but I guess that just the life of us Levo's. Jaks a bit down at the moment but he will be good in a year or two.  We are now on a  quest for another 850 trx engine ,so if any of you guys know where we can find one would be a great help.
Also to Bruce and Nars thanks for the great weekend plus CLQ a great group of people'
        Levo
Post by: Cosi on October 10, 2019, 10:47
I remember riding there and riding home but seem to have missed the bit in the middle somehow...
Post by: andre g on October 10, 2019, 17:58
Oh yeah, another Petrol Station pic! ;D
I know it is the safest place to make some photos during a trip
Post by: DavidH on October 11, 2019, 05:10
Apologies Tony,
names I'm not good with, but colours, mmmm.  That is the strangest orange I've seen on a LAV, but no matter.
Great looking and performing JOTA, aided by rider and pillion.
Good to hear the offer of the van was taken up and the young fella has seen the light and knows how LAV owners work together when things go pearshape.
Post by: Piranha Brother 2 on October 14, 2019, 00:20
What goes awry with a TRX??
Thanks for the reports and pics, y'all. Great to hear about riding adventures and Lavs. Badly need to get out there myself. My spesh gets a little closer each week ...
Post by: Vince on October 14, 2019, 02:29
TRXs don't do well trying to keep up with a Motod on the Putty Rd, ask my cousin. It was a bit of a mess lowsiding and sliding into the armco on the narrowest section of the 10 miles. Luckily rider was fine. Very acquired with nowhere to park and assist on a blind bend
Post by: motoddrob on October 14, 2019, 04:44
Was that your cousin Vince?? I remember that well. I reeled him in and was watching him constantly looking in his review mirror so he put himself under pressure. Cracked an engine cover so we got him to Broke I think then left him for recovery. Gotta watch those Motodds :o :o 8)
Post by: Vince on October 14, 2019, 05:36
Yep, he has one of those massively fast 4 cylinders supposedly off-road BMWs now. His brother came on the last Putty ride we did a month ago. Had some interesting major bike injuries with both mainly off-road crashes, I tend to get the look from there Mum my Aunty at family events.
Post by: Tippie on October 14, 2019, 06:46
"constantly looking in his review mirror" BIG MISTAKE. Never concentrate on what is behind you, other than a quick glance now and then (if riding on the road).
Great to see that you still having these gatherings and so many make the effort. I thought you had moved out, back to Bris or something, Bruce.
Post by: Vince on October 14, 2019, 07:02
My second run on a race track had the same effect, I was watching the craziness happening behind heading into turn 1. Next time I will push the mirrors in, I didnt need to see them heading in 3 and 4 wide behind me.
Post by: Piranha Brother 2 on October 14, 2019, 23:22
Mirrors??? On a race track??? Even on track days you surely can't ride with mirrors???  :-\
Post by: Vince on October 15, 2019, 00:16
5 parade laps at lunchtime at one of the Barrys, 120 vehicles including a VW trike and a couple of sidecars. Some bearing doing the speed limit and some completely berserk and well above there skill level. I got passed by one very fast fellow pulling a crazy line really tight into turn 1 riding a Harley Softtail. Heard later it was Troy Corsa. That was fine, plenty of room, the earlier lap had the 3 and 4 wide boys passing me on both sides. My last time doing that, at least track days have no inside passing rules and people with some experience.
Post by: Cosi on October 15, 2019, 03:02
I went past you 4 times ;D
Post by: Vince on October 15, 2019, 08:32
It took 4 laps to know where the blind bends went, and I had zero idea how fast or where to brake for turn 1. If I ever manage to fit into the 2 piece leather suit I have acquired some track experience would be huge fun. I missed the CIMMA track days being away from Sydney this year. The original parade only all Laverdas prade laps years ago, 26 Laverdas was great fun and a hell of a lot safer.
Post by: motoddrob on October 16, 2019, 00:57
How can you live in Sydney and not do track days Vince? I managed to do a few at Eastern Creek and Oran Park. After seeing the new extended track at Collie I'm keen to start doing a few again, good excuse to get the SFC out again and give the Motodd a serious thrashing. Trouble is it's 300 kays away!!. Also promising is a plan to build a Motoplex in Albany with a track 3.5kays long. I really hope it goes ahead as that's only 120 kays away. Apparently it was an election promise so it'll probably never happen!! Track days are the future of hooning a motorcycle as it's getting seriously fuck up trying to have fun on the roads now. And in WA there isn't many roads that are fun to ride and the few that are are heavily policed, bit like the old road.
Post by: Legs on October 16, 2019, 01:06
No need to have track days in Adelaide or the hills to have fun, if you know where to go  :-X
Post by: motoddrob on October 16, 2019, 01:23
No Adelaide hills in WA Terry unfortunately. Where I live there is 1 road in and the same road out of town and that's Hwy1 and posted 90km/h for most of it and policed. However there is a farm road that leaves and reconnects the Highway 40 kays long and very rarely see a car let alone cops on it but to have fun your going pretty fast and if you fuck up it's going to hurt. How I long for those 50, 60, 70 kay posted corners. Track days are my only option to have serious fun apart from riding the bush tracks on the GS BM but that's not speed though.
Post by: Legs on October 16, 2019, 02:43
I feel for you over in WA, One of the reasons I stayed in SA instead of moving over to the west with the Collins submarine project (meant to move from Sydney to SA while the boats were built, then to WA when they were commissioned), the two years I stayed in SA opened my eyes as just how good a motorcycling mecca it is, been here ever since. Beats Sydney hands down for motorcycle fun  :D
Post by: Piranha Brother 2 on October 16, 2019, 12:21
Vic has some seriously good moto roads, but to avoid the plod you need to move right away from popular bike hotspots and seek the interesting backroads. While track days are fun, brisk riding on backroads, with survival in mind, is a fantastic experience, especially on a well sorted Lav.
WA was always a particular kind of fast riding - but anywhere near a town or on a main highway and you wouldn't last 10 minutes at the sort of speed where it becomes exciting (which happen to be lockup and licence evaporation speeds in today's wonderful world).
Post by: Cosi on October 16, 2019, 14:23
Some of us still like the cat n mouse challenge ....
Post by: markQLD on October 16, 2019, 14:27
 .. and some of us still like a cold beer at the pub, out in the middle of BFN ..
Post by: 81Lav on October 19, 2019, 00:33
Yeah currently living in Brisbane Lee, we still have the farm in Bello. No work in Bello for me!
BK
