Author Topic: 83 1200TS - DPO issues  (Read 2477 times)
Offline r.bartlett
  • Jr. Member
« on: May 16, 2019, 15:06 »
Ok, new lever and silencers are on but Ted my mechanic has found a number of PO issues..He's pretty certain the engine has been torn down not too long ago but on running he was disturbed by the rattling. Oh and a lot of blue smoke which is more worrying
Removing the cam cover revealed the cam chain was so loose he was surprised it hadn't jumped a tooth. He's tightened it
Primary chain sounds as bad but he hasn't yet taken that cover off. although cover has sustained accident damage at some point.
someone has linked across a relay not sure what it is or why?
compression test
l/h 125
mid 75
r/h 109
he said there is cross over between the two so thinks the Head gasket may have blown... Top end off time :-)
not happy with the non standard air filters, said the triples struggle with these K&N's .. I should try to source OEM
trigger electroncs look rough, consider replacing primary cover see damage and ign set up.
the tacho drive seems to be missing something?. we found the inner ( see previous thread about rev cable ) which had slipped from the tacho gauge down inside the outer to the top of the engine.
He suggests a 'home enthusiast' engineer level has been tinkering with this for some time....
I guess this is just the start of a beautiful friendship  ;D
Does this make sense ?
Offline Piranha Brother 2
  • Hero Member
  • It was once a 1973 750 SF1
Re: 83 1200TS - DPO issues
« Reply #1 on: May 16, 2019, 23:49 »
Probably better in the Technical thread. Classic DPO symptoms - judging by the condition of the motore I'd be tempted to go a full stripdown. It will save you money in the long run - quite a lot of money potentially.
Offline maurice turner
  • Hero Member
« Reply #2 on: May 18, 2019, 00:58 »
Hate to disapoint you but start from zero you need to know about whats going on in there!
81 Jota*7604*
Offline chrisk
  • Hero Member
  • I'd like to write something here: SOMETHING
« Reply #3 on: May 19, 2019, 04:21 »
 :o Touring around on a 1200 you don’t know could have its pitfalls....... if you know what I mean?
"Team BFN - an international rabble on wheels"🏍🍻👍🤣😍
Offline IAG
  • Hero Member
  • Chicago
« Reply #4 on: May 19, 2019, 18:10 »
That is rusty & crusty! Been sitting in water or on the coast of an island? Do a leak down test for #2 to determine failure but tear down imminent.
1976 RR Clone #5148
American Eagle #1650
1984 RGS Executive #10 (#2320)
Offline sfcpiet
  • Administrator
  • Hero Member
  • NRW, Germany
« Reply #5 on: May 20, 2019, 09:31 »
I see this sort of stuff every other week, quite sad to see these fine bikes in such neglected condition.  Guess it's a testimony to their ruggedness, they'll keep on going until they are well and truely run into the ground.
A parts book will help establish what's missing, you'll be surprised... ;D
Offline r.bartlett
  • Jr. Member
« Reply #6 on: May 20, 2019, 18:40 »
yes we're on to it.. :o
Offline r.bartlett
  • Jr. Member
« Reply #7 on: May 20, 2019, 18:41 »
we are pulling the motor out for a full tear down...
Offline pf1
  • Hero Member
« Reply #8 on: May 20, 2019, 20:38 »
The trouble seems to start with the home mechanic trying to shim the valves on these Spanish triples, they mess that up and its downhill from there.
The one I've just bought from there is an absolute disaster zone in the valve clearance area. All the shims have been ground down to below the smallest standard shim size, each one is around 1.7mm thick and the exhaust valve clearances are huge, one shim is smashed to bits and the other two are at 0.8mm when they should be 0.25mm. It must have rattled like hell before it gave up.
Offline chrisk
  • Hero Member
« Reply #9 on: May 20, 2019, 21:51 »
Oops, what’s this long blade thing doing down the cam chain tunnel?
She’ll be right mate, it won’t need it......
  • Hero Member
« Reply #10 on: May 21, 2019, 01:34 »
Good work pulling it down. Pretty clear now that you had little choice. Imagine the damage if you continued using it like that! As i said, it can end up VERY costly!
Good luck sorting it.
Offline CLEMTOG
  • Hero Member
« Reply #11 on: May 21, 2019, 11:02 »
I see you discovered that the head and cylinders wont come off in situ without pulling studs and removing ignition hardware from the frame etc.
Is that a locating dowel on one of the head studs (with a ding), I have heard of that before somewhere but I am reasonably sure that it is not a factory original item, early triples had just a plain gasket, almost all of them (ie later) had an enlarged hole for four of the oil bearing studs to allow an O ring to be installed with the gasket, this also meant that the metal flame ring was cropped a tad to give enough room, I have no idea why they didn't do that for the other two oil bearing studs, but I guess that the system did work.
It has always puzzled me why there are no locating dowels for most joint faces, such as head, barrels, primary cover, gearbox cover etc. Installing them on the head barrel joint must be a great idea for both location and oil retention.
Offline Grant
  • Hero Member
« Reply #12 on: May 21, 2019, 11:22 »
A small batch in the series 2 range had dowels between head and barrels.
I have found only 2 series 2 engines with dowels so far, out  of several.
Check out my FB page, clublaverda.com
Offline CLEMTOG
  • Hero Member
« Reply #13 on: May 21, 2019, 15:22 »
but was that factory?
Piet?
Offline Grant
  • Hero Member
« Reply #14 on: May 21, 2019, 17:19 »
Yes
