Author Topic: SF2 tappet adjusters  (Read 657 times)
Offline markQLD
  • Hero Member
  • from da cane fields
Re: SF2 tappet adjusters
« Reply #15 on: August 02, 2020, 07:57 »
This from our spare parts supremo Brett
Nuevo genuino Rotax / Aprilia válvula de ajuste Tornillo ap0240205
, and one hopes Brett also knows of a low cost supplier.
I thought Rotax UK was just a tad high?  (dunno)  no?
Ya gotta luv ya Lav  8)
Offline The Sock
  • Full Member
  • '76 3cE, Owned from new.
« Reply #16 on: August 02, 2020, 08:10 »
 :o Are they made of Platinum?
'76 3cE, owned since new.
Offline AndyW
  • Hero Member
  • Mali
« Reply #17 on: August 02, 2020, 08:11 »
P & M recommended mushroom headed tappets over elephants foot type on both my T160 and Hurricane: far easier to measure the clearance correctly too.
'71 TR6 Tiger, '73 X-75, '73 3C, '74 3C, '75 SF2, '75 850T3 Cal, '75 T160V, '78 Mirage, ‘78 SSD Darmah '80 SD Darmah, '82 TR7/T, '83 Tenere, '85 R80g/s, 2017 MV F3 (Ago edition)
Offline Thomas aus LAU
  • Full Member
« Reply #18 on: August 02, 2020, 09:54 »
Offline Piranha Brother 2
  • Hero Member
  • It was once a 1973 750 SF1
« Reply #19 on: August 02, 2020, 14:10 »
Not where I bought mine!! They must have been out of stock. Hard to read, but AU$16.75 ea.
« Last Edit: August 02, 2020, 14:14 by Piranha Brother 2 »
Offline Paul Marx
  • Hero Member
« Reply #20 on: August 02, 2020, 18:27 »
Thanks for the reference.
Will be on my purchase list.
Offline Laverda SF
  • Hero Member
« Reply #21 on: August 03, 2020, 01:19 »
Marty: Recommend you use a Dial Indicator (Fit it any way you can) to adjust the tappets on your Breganzie 750 SOHC Twin as them Tappet Screws do tend to leave divots and the cam follower can be beveled which a feeler gauge will not measure.
Feeler Gauges will give you an approximation but a Dial Indicator will put you right on and don't forget to check the tappet clearance again after you have torqued the tappet nut and screw ;o)
PS: Some of them tappet screws and nuts can be brittle so be vigilant - Especially if your going after 7600rpm+.
« Last Edit: August 03, 2020, 04:09 by Laverda SF »
North Shore Lake Huron, Ontario Canada, home town Capreol just north of Sudbury Ontario. Presently living in Spanish.
I cannot list the motorcycles I've worked on or ridden - Just too many.
The thing is: I loved to race and I'm still alive. Gotta say that 70 SFO 750 Breganzie is a racer.
Offline martymoose
  • Hero Member
« Reply #22 on: August 03, 2020, 09:59 »
Hey Q how come you only ordered 2?  I just ordered 4 through work from aprilia, $20 each retail.  Only problem is they are in italy, 8 weeks wait
Cheers from sunny Sydney
  • Hero Member
« Reply #23 on: August 03, 2020, 13:46 »
May have been they had until a new stock load arrived - I would have nabbed what they had so I had a sample to set up the rockers for clearance.
Is there an Aprilia that uses Rotax donks? Did you try Floods in Melbourne? No delay with shipping and only $17.50 when I bought those two. If I wasn't confined to quarters I'd ride out to Lilydale and pick them up for you!!
Offline Paul Marx
  • Hero Member
« Reply #24 on: August 03, 2020, 18:27 »
I think all big Aprilias used Rotax engines. The 750 V twin was the first in house engine I believe.
