Author Topic: Clutch lever / mount for 78 Mirage  (Read 238 times)
Offline Digger
  • Newbie
  • Bristol, UK
« on: May 16, 2018, 21:27 »
Good evening
I'm struggling to find a replacement clutch lever for my 78 Mirage. Mine is very worn at the pivot and causing gear selection issues. I understand it's a Tomaselli item (?).  Slaters don't have one.  Laverda Paradies list it but don't have any stock.  Could I fit a complete Domino item as that may be easier to get ?
Thanks in advance.
1978 Mirage - 1630
Online laverdas
  • Hero Member
Re: Clutch lever / mount for 78 Mirage
« Reply #1 on: May 16, 2018, 22:23 »
hi, i put a bush in mine which wasn't a hard or time consuming job and it works fine
Offline Digger
  • Newbie
  • Bristol, UK
« Reply #2 on: May 16, 2018, 22:33 »
I did have one put in a while ago but it wasn't done that well.  I may find someone else to do it.
1978 Mirage - 1630
Offline redax5
  • Administrator
  • Hero Member
  • All 81's, a fine year indeed
« Reply #3 on: May 16, 2018, 23:08 »
Wolfgang has them in stock, bought quite a few from him recently
Redax Drilling Consultants, confirmed Laverda tragic's
near Brisbane, Australia
Offline Digger
  • Newbie
  • Bristol, UK
« Reply #4 on: May 17, 2018, 09:00 »
That's great. Thanks for that.  I've emailed him  :)
1978 Mirage - 1630
Offline LJ
  • Hero Member
« Reply #5 on: May 17, 2018, 18:10 »
he may be away at the moment,
1986 RGA Jota Sprint
1974 3C
1973 750GT
1971  750SF
 I was born to make mistakes,not to fake perfection
Online Normski
  • Sr. Member
« Reply #6 on: May 17, 2018, 18:44 »
That Lever assembly may be common to  some Guzzis  in which case you could try Guzzibits if Wolfgang is away.However your gear selection issues may be caused by poor adjustment of the eccentric in the gear selector mechanism.
Offline Paul Marx
  • Hero Member
    • Les motos de Paul
« Reply #7 on: May 17, 2018, 19:43 »
Clutchless changes. No selection problems.
Offline Digger
  • Newbie
  • Bristol, UK
« Reply #8 on: May 17, 2018, 19:49 »
Thanks all.  Wolfgang has responded and I've ordered a lever assembly.
Thanks Normski, yes, I'm adjusting the eccentric.  And sorting the rearset linkage issues I have which aren't helping.
And replacing the warped front discs.  And getting it going after 3 years of it stood idle etc etc  :)
1978 Mirage - 1630
Offline Paul Marx
  • Hero Member
    • Les motos de Paul
« Reply #9 on: May 17, 2018, 21:06 »
Sticking clutch?
Offline Digger
  • Newbie
  • Bristol, UK
« Reply #10 on: May 17, 2018, 21:44 »
I don't think so.  Seems OK.
1978 Mirage - 1630
