Author Topic: Universal centre stand  (Read 744 times)
Offline phil37
  • Hero Member
  • Lincolnshire
« on: February 21, 2018, 17:08 »
I expect some of you are already familiar with this type of stand - but I've only just come across it. It's made by Sealey and was £37 delivered (UK). It would be very useful for front wheel removal on the 750's as the front heavy bias makes it a pain. It's easily fitted and removed and the bike remains in a strong and stable position that even saint Theresa May would be proud of! With some spacing wood underneath it also fits an off road bike on its maximum height setting. - Regards - Phil
Offline Piranha Brother 2
  • Hero Member
  • It was once a 1973 SF750
Re: Universal centre stand
« Reply #1 on: February 21, 2018, 22:41 »
Clever idea. I use two old Holden bottle jacks on mine, but that would be a lot bloody simpler. Shame it's sold in the UK and not in convictland!
Offline chrisk
  • Hero Member
  • I'd like to write something here: SOMETHING
« Reply #2 on: February 21, 2018, 22:46 »
It is a clever idea, except for those motorbikes that have exhaust underneath it.
The initial attraction to motorcycling inflicts people for various reasons and at different stages in their lives. But once someone experiences the elation of riding a motorcycle there’s no denying the nearly spiritual effect it has.
Offline Dellortoman
  • Hero Member
« Reply #3 on: February 21, 2018, 22:57 »
You're handy with the tools aren't you Quentin? It wouldn't take more than a couple of hours with a hacksaw and welder to make something similar.
I was having similar thoughts to Chris though. It wouldn't suit most of my bikes because of the exhausts or fairing belly pan getting in the way. Laverdas usually have their own centre stand anyway. Something like that might be handy for my Yamaha TY350 on the rare occasions that thing gets any attention in the workshop.
Offline AndyW
  • Hero Member
  • Adelaide
« Reply #4 on: February 21, 2018, 23:14 »
You could easily make one with protruding (semi-spherical) lugs correctly spaced to engage with the frame rails...
'71 TR6 Tiger, '73 X-75, '73 3C, '74 3C, '75 SF2, '75 850T3 Cal, '75 T160V, '78 Mirage, '80 Darmah, '82 TR7/T, '83 Tenere, '97 XRV750, 2017 MV F3 (Ago edition)
Offline chrisk
  • Hero Member
« Reply #5 on: February 21, 2018, 23:21 »
Unless you owned an SF or SFC.
Offline AndyW
  • Hero Member
  • Adelaide
« Reply #6 on: February 21, 2018, 23:44 »
ok, space the lugs to engage with the downpipes.. (bolt)
Offline Laverdalothar
  • Hero Member
« Reply #7 on: February 22, 2018, 08:43 »
I have one of these and they do work with Laverda (Breganze) triples and twins:
https://www.louis.de/artikel/rothewald-scherenheber-mit-adaptern/10003265?filter_article_number=10003265&list=362c3bb8fa728bce701702f89882999d
There are two sliders that you can put on the top, they can be adjusted to the width of the lower frame-tubes width f.e., then tightened with a screw so they do not move. there are 3 different length of adapters coming with it (I use the middle length). If you use a cordless screwdriver, an adapter and a wrench socket fitting to the end of it, it is a one person operation to lift the bike...
there is also the black series existing for roughly 30 € more. The only difference I can see is that that one is powder-coated and has 2 angled metal brackets bolted to it to keep the thing from tilting. This would only be necessary from my point of view if you extend the lift fully (Cross bikes f.e.). Haven't had any issues so far with the red one except for a broken bearing.
cheers
Lothar
« Last Edit: February 22, 2018, 08:52 by Laverdalothar »
750 SF(0) 1971 #9934 *sold*
1000 SFC Classic 1989 #3367 *sold*
1000 SFC 1985 #2934 currently under restoration
1000 SFC Preproduction bike 1985 #0001 *sold*
1200 Jota 1981 #7474
750 S-Formula 2000 #1602
1000 Motoplast - currently under construction
Offline Ventodue
  • Hero Member
« Reply #8 on: February 23, 2018, 18:29 »
Like that, Lothar.  Might be worth a thought ...
Thanks.
Craig
Offline MotoJouni
  • Sr. Member
  • Finland
« Reply #9 on: February 23, 2018, 21:00 »
I have made such plank. Dimensions are 33x70mm (can't remember length of it) and I have planed it from one corner to fit where it is. I think it is spruce that have grown up slowly and therefore strong enough. Also spruce withstands variation
of humidity quite well. No even need to remove exhaust system when working with the frontend,
which would otherwise lead to many retightenings again.
SFC 1000 Classic 1989
LB 125 Custom 1986
Ducati Paso 750
And many other old vehicles
Offline chrisk
  • Hero Member
« Reply #10 on: February 23, 2018, 22:31 »
Writing reads SFC ................ when packaged. What is the rest?
Offline MotoJouni
  • Sr. Member
  • Finland
« Reply #11 on: February 24, 2018, 12:59 »
Can be understood "SFC stand accepts exhaust system"
I was writing that text in middle of the night and somewere on the center of the wooden block
I noticed there was no room to write what I was going to with same size of letters and phrasing became some kind of brain fart but still understandable.
Idea was to write something to it or someone would use that peace of wood or throw it to rubbish.
« Last Edit: February 24, 2018, 13:01 by MotoJouni »
LB 125 Custom 1986
Ducati Paso 750
Offline drikko
  • Hero Member
  • Brisvegas
« Reply #12 on: February 24, 2018, 21:29 »
cheers
Lothar
Or for a quarter of the price...  https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com.au%2Fulk%2Fitm%2F332466809053
Rgs1000 '83
Triumph Sprint ST1050
Cosi prefers crow eaters....
Breville Sandwich Maker
DISCLAIMER:- Anything I say may have been when I was sober so please don't take it personally.
'Bigamy is having one wife/husband too many. Monogamy is the same.' Oscar Wilde
