Author Topic: What did you do to or for or with your Laverda today?  (Read 45627 times)
Offline Legs
  • Hero Member
« Reply #30 on: October 02, 2017, 02:49 »
Noticed the side-stand was a bit slow to retract on yesterday's ride. Dismantled, cleaned, greased and put back together this morning. Got to keep on top of the little things ;)
Offline Chalkie
  • Newbie
« Reply #31 on: October 06, 2017, 22:06 »
Dropped my engine off at Laverda Soczia for Keith to give it the works.
Time to start saving!
Worth it
Remember a pessimist is what an optimist calls a realist???
Offline Dellortoman
  • Hero Member
« Reply #32 on: October 07, 2017, 01:03 »
Worth it
You're not expecting a quick turn-around then  :D
Offline Chalkie
  • Newbie
« Reply #33 on: October 07, 2017, 22:55 »
No, Keith told me I am about 10th in the list.
But at the rate I am doing the rest that's fine.
I can wait
Offline padlock
  • Hero Member
« Reply #34 on: October 08, 2017, 19:33 »
Worth it
Ill give you a clue. Dropped mine off a year ago only just got to the front of the queue. But yes, will be worth every not inconsiderable penny.
FFFANARCHY
If your going through hell, keep going.
Offline chrisk
  • Hero Member
  • I'd like to write something here: SOMETHING
« Reply #35 on: October 11, 2017, 00:43 »
Ha ha ...........he will like that,he owns the P&M  :D......but i will be sure to keep an eye on him  ::)
That P&M Kawasaki looks very tidy.
The initial attraction to motorcycling inflicts people for various reasons and at different stages in their lives. But once someone experiences the elation of riding a motorcycle theres no denying the nearly spiritual effect it has.
Offline Lee87H
  • Sr. Member
« Reply #36 on: October 13, 2017, 20:35 »
Pulled cover off of shift mechanism and installed washer over shifty shaft return spring as it came off of stud, works great now, thanks Piet,   Cheers
74 SF2
78 1000 3-CL
66 Montesa 250 Impala
74 Bultaco 250 Pursang
74 Bultaco 360 Pursang
79 Bultaco 350 Sherpa T
00 Buell 1200 Cyclone
Offline MotoJouni
  • Sr. Member
  • Finland
« Reply #37 on: October 13, 2017, 23:35 »
Nothing actually, but manufactured a tool on my metal lathe for changing valve guides to BMW K100/K75 engines to be overhauled at the moment. Handle section was not machined because there was no little bit thicker bar on stock to that purpose at the moment, and therefore is not made to higher standards required for Laverda tools ;)
Just got it manufactured and wondered if it is also suitable to Laverda triples, didn't thought that earlier to make the same tool to fit if possible. I don't remember dimensions for Laverda triple valve guides, length of the guide and suitable biggest diameter for the tool. But not actually even needed at the moment.
SFC 1000 Classic 1989
LB 125 Custom 1986
Ducati Paso 750
And many other old vehicles
Offline Piranha Brother 2
  • Hero Member
  • It was once a 1973 SF750
« Reply #38 on: October 14, 2017, 00:20 »
Can't see from pic, but I made mine (twin guides, similar seal section to triples) so a recessed section fits over the fragile top section where the seals fit - this avoids damaging that thin section when hammering them in. Can also be a sleeve that fits over the std type punch.
Offline MotoJouni
  • Sr. Member
  • Finland
« Reply #39 on: October 14, 2017, 01:15 »
Good point. This tool alone is to take the old ones out. Must take more dimensions when I got some valve guides on hand to make suitable sleeves for hammering new ones in. Earlier we used propane/butane torch to heat up cylinder heads, but that needed a lot of attention. Now I have an electric oven to that purpose.
LB 125 Custom 1986
Ducati Paso 750
Offline Dellortoman
  • Hero Member
« Reply #40 on: October 14, 2017, 01:17 »
And you can heat up your pies at the same time  :D
Offline MotoJouni
  • Sr. Member
  • Finland
« Reply #41 on: October 14, 2017, 01:18 »
Yes and to get a good metallic and oily taste to that pie :)
LB 125 Custom 1986
Ducati Paso 750
Offline bazzee
  • Hero Member
« Reply #42 on: October 14, 2017, 06:17 »
There are instructions on replacing valve guides in laverdapedia.
bazzee
Offline MotoJouni
  • Sr. Member
  • Finland
« Reply #43 on: October 14, 2017, 11:48 »
bazzee
Thanks, found this document:
www.laverdapedia.com/Valve%20Guide%20replacement.pdf
LB 125 Custom 1986
Ducati Paso 750
Offline Rob
  • Hero Member
  • Midlands, UK
« Reply #44 on: October 14, 2017, 12:59 »
Key piece of info in Red's opening comment -
Generally not a job that the average home mechanic can carry out, but here follows the method
that we use.
Alternative approach that minimises loss of shim size through recutting seats is to get a set of oversize valves (stem) and ream existing guides
