Hi All,
I’ve been following this Forum for a couple of years now but this is an early foray into contributing. Please be gentle with me !!
I have a 1977 Mirage awaiting restoration. It’s a very early one in the original Green. Although the paintwork is ok I plan to have it resprayed to “freshen” it up during the restoration.
I sent a side panel to a local paint suppliers for analysis and they came back with a Green metallic from the 1975 BMW Motorcycle colour palette. I don’t know the BMW code but from PPG it’s code is PPG0006. They supplied a painted sample and it’s very nearly perfect - allowing for deterioration in the side panel over the last 30+ years and metallics reflecting different in changing light and angle. My painter tells me metallics are notoriously difficult to replicate because of many factors such as gun pressure and settings, spray angle, paint build etc.
It’s a solvent based two-pack that you spray on the colour base coat first followed by a lacquer. It’s quite expensive at £35 +VAT per half litre. My painter reckons you might get a tank, two side panels and a ducktail from just over half a litre – but better get a litre just in case !
If anyone wants to PM or email me I’ll be pleased to get some more samples done for you and if we all agree we’ve cracked it.
The Yellow “Mirage” lettering on the side panel is painted on with a stencil. I have seen some Green Mirages with raised metal “Mirage” badges but I don’t know if they’re correct in period, or from a later model Mirage. I’m sure someone out there knows the answer to that. I don’t have a match for the Yellow yet but the paint suppliers advise it shouldn’t be a problem. Making a stencil is quite easy if you have an example of the original lettering which we have.
Paul – I have to finish my restoration of a 1977 Jarota before I get onto the Mirage. It’s going to be a while before I get the Mirage restoration to a point where I’ll need the panels for painting so if you cover the costs and promise to return it in a few months time, I’ll be please to send you a side-panel for you to do your own investigation. PM or email me.
Hope this helps.
Paul.
Hi Paul
very kind offer. Where are you in the world?
the BMW folk are even more anal than us laverda nuts, lots of specific BMW info on the web
http://www.bmbikes.co.uk/paintcodes/greens.htmfrom around 1975 looks like there was a Nuerburg green for the 75/76 R60/6 and R90/6, BMW code 577, a metallic Nuerburg green BMW paint code 077, a BMW green metallic BMW paint code 074 used on the 73/74 R50/5 and R90/6, and then there also was a bright Minz green I don't have a BMW code for...
the first photo attached in teh BMW green metallic BMW paint code 074
the second photo attached is the BMW Nuerburg metallic green, BMW paint code 077
this is really tough to do over the internet, but best I have at the moment. Have a look and see what you think.
I am going to have to find a local paint shop with 1975 BMW motorcycle paint colour charts and have a look in the flesh,I couldn't find any PPG charts online to check PPG 0006 in 1975 BMW green......
Paul LeClair
